Thank you for your responseSilent_chaos said:1) Rampage xb gears are 29 31 25 25.2) if you want top speed, you need to install 35 25 25 25.
You can purchase that 35 tooth gear from redcat websites or largescalerc.com or davesmotors.com
But when you install this, you will lose torque, and the car will not get up from the ground fastly. It will be faster in the long run yes, but the 1st 5 seconds will be very slow till it picks up
3) refer above
4) bonus: you can always get a 2 speed transmission from DemonRc. This way you can tune for torque and a good top speed. You can calculate the ratios in their website and see which one suits you best.
(See the adds on the left side of the page
(Ya3ne byeje gheyaren, enta bt7added 3ala ayya rpm yghayyer la tene gheyar)
Thank you for your responsercgasser said:You can switch you A and B gears only for more top speed. If you switch to a 8K clutch you will not lose much torque at all after switching the A and B gears.
Yes. Those are the gears.Abdulrahman said:Thank you for your responseDid you mean this gears set ?
http://www.davesmotors.com/redcat-07188-25-tooth-steel-gear-for-rampage.html
http://www.davesmotors.com/redcat-07184-35-tooth-steel-gear-for-rampage.html
I will change the engine and I will put the zenoah (G320RC) engine, I think this engine have maximum torque so i want highest gear ratios.
Mine didn't..?BertR said:The xb comes with a 26/24 c&d gear
