rampage xb - xt mod
don't they just mount to the shocktower front and back.Look on page 7 of the manual they show it for the rally but its the same for the xt.
im not sher the XT buggy onley has the 3 post as the XT has 4 plus the XT has the longer body posts to rase the body above the shock posts so thats y i was asking if the XT body posts would mount on to the xb
Yes they will... The XB, XT and the XB-E share many of the same parts...
I used converted my XB-E to use the truck body... Now it's and XT-E... :D
When you mount the front posts... be sure to use the front braces it will help support the front shock tower.
The MT and TT are the same platform.
The X Series platform is totally different.
The MT and XT bodies are the same though.
rcgasser said:
The xt tires will lift it off of the ground quit a bit i don't know of any mod to get even more clearance.
take the lower shock mounts off and switch them left arm to right arm and it will ad a hair more clearance without binding dogbones. I run the xb stock to keep it on the ground and my xt this reversed way to use the shock travel a little more...
