rampage xt-beginner
vargasgil
Junior Member
chicago,il
I received my rampage xt in the mail today. Put it together. Mixed lucas semisynthetic 2 cycle with 92 octane at 25:1 ratio. The first tank is almost done and vehicle will barely move when I give it throttle, then sometimes dies out. I have not made any adjustments to anything on vehicle and am wondering if this is normal for break-in period. Also, I noticed throttle rod is hitting air filter and seems to not go all the way back, normal?
Welcome to the forum re adjust your High speed needle and low speed...the high speed clockwise till it stops then back out 1-1/4 turns do the same with the low speed needle but back out 1-1/2 turns and see if that helps and check your trim for the throttle and you may have to tweek the rod just a tad to clear the filter.
Also make sure the duel rate is all the way up on the stock Raido...welcome to the forum
Got it running, broken in. Thanks
Did have to repair exhaust bolts one was bent at assembly and wouldn't allow proper seal And managed to break body and upper control arm on jump
