The rebuild is complete. I have a few more things more to put on: a buggy body from Ron E and if I like the Dark Soul marine head then that but with a 27.2 kit, either a cage or roll hoop, and chassis braces. I didnt mesh the crankcase because if I put in the DS marine head it might not need mesh. I decided to use the
668 instead of the 813. I might do the 813 later. It was completly stripped cleaned, lubed, retightened screws with loctite. I sprayed all of the plastic w/wd40 to keep the dirt from sticking for a while. I had the upgrade kit but had not installed the parts yet. Specs before the rebuild: MT v1, 28.5, 8k spring, HPI filter, Hitec servos, side dom, pullstart cover, excavators/desperados, 5b hexes, 3000 batt, 3rd channel failsafe, fhss2, 5b shocks, go pro camera mount on roof.Heres the stuff that went into the rebuild: new gears (all 4), outerwears prefilter, stock shocks w/5mm shock shafts, 50r/60f wt shock oil, v2 shock springs, fuel line, blue choke handle, 5b wing, wing mount (allows use of mt bumpers/skids), buggy body, Zrc carb manifold, shreadstack, chrome wheels, yellow beadlocks, proline bowtie f+r, chrome fan cover shroud, v2 gearplate, v2 vented clutch bell, dogbone leashes, 4200 batt, carb gaskets.
/monthly_2010_02/100_1121.jpg.d1de04b06ba16720124da2455bb4efc9.jpg
/monthly_2010_02/100_1118.jpg.a0d177fa82503705120c3a5deae48e43.jpg
/monthly_2010_02/100_1113.jpg.c6eae856009065294c4765e46b234727.jpg
/monthly_2010_02/100_1114.jpg.36f3910d42b184214a683ad99629639c.jpg
