Rossco
- Victoria,Australia
I have just rebuilt my engine to CY GP290 specs, 36mm bore, 28mm stroke, (cylinder,crank,piston,pin,pin bearing&washers,ring,case bearings,seals,gaskets etc etc, all brand new CY!!!)
It screams like a banshee in heat up top & has mobs of grunt down low, as one would expect,,,,BUT,, it has a metalic rattle when I shut down.
I suspect it may be the pin washers.
Anyone else had this with their engines?
