Re wire
CyberVet65
Cedar City, Utah
The truck has been apart for a while. I do not remember the wiring on some things.
New coil. The red wire next to the engine and black wire outside?
Steering plug into the receiver. What channel?
Can the kill switch be wired to channel three?
Is there a problem mounting the battery pack on the outside of the receiver box?
All the wiring makes for an impossible fit. I would rather keep the electronics clean. Easier to charge battery if velcroed in place.
Getting close.
Tires will be here next week. Putting Split Six wheels with TRenchers.
Almost ready to mix some gas! :eek:
Your steering servo goes in channel 1 throttle servo channel two and kill switch channel three you can keep your battery in the receiver box and just use a y spit wire connected to channel three cut a slot in the box and run the wires outside the box that way you wouldn't have to open up receiver box again
