dwarfy
Ive given the marder a full check over before taking it out on Sunday for the 1st time in months. Here's what Ive done:
Changed the shock oil all round for 2000wt FG oil (not sure what was in before)
Changed wheel bearings on back RH corner. They were well shot and the drive cup was moving around like a stick in a bucket.
Installed a new Bluebird 630mg servo with 14kg torque in place of the Hitec 645mg which seemed underpowered for the front tuning brakes.
Adjusted front cables brakes.
Removed the layshaft brake and rod. Going to see how it performs with just the fronts and new servo.
Set the wheel cambers and alignment using Trip's tape method! The back corner with the shot bearings was a mile out.
Its as good as its ever been now but I remember it bogging slightly at low revs before taking off like a scalded cat so will prob need a tune on the L needle. If it bogs does that mean its a bit on the lean side? I will give it a tweak & let you know how it runs :cup-1:
