Rear brake assy
Definately a little different but I was able to find the parts in your link,and I think yours is right compared to mine,but I would still like to see some pics:)
yup that will fit onto the standard layshaft. it will work allot better too. stock is steel pads with fibre disc. this is the other way around and really how it should have been from the factory.
you also need the motor side plate. I have the 97 on my truck. there's an aluminum part that screws onto the motor side plate. I haven't tried with a normal side plate... my alloy one is a normal but going to put rear discs on
Thx bud,I have front disc brakes now and they work well,so I guess I don't need the rear stock assy.I don't think you can run the stock rear with the front discs off of one servo that also operates the throttle:detective:What I really need then is a couple of pics of the linkage from the servo to the cables,the guy who had this,although it works,looks like it won't hold up too long,have a look here:detective:
