rear brake pads ?
mhansen644
Reading the Rules!
HI I have a fg baja that I got used and the rear main brake pads only have a pad on one side of the brake disc and a metal plate on the the other side of the disc? Is this correct or should It have a pad on both sides? the part # I am refering to is 8456 I think. I think 8456 is the pad not the metal plate?
http://www.rctube.eu/download/rc/in...dellsport_Sportline_Touring_Exploded_View.pdf
is your set up like this
http://www.rapid-racing.co.uk/productlist.asp?keyword=true&paging=1
2 steel plates rubbing against an epoxy disc.......or is it a steel disc with one of the brake linings missing??
Brake disk epoxy 97 - new 1 pcs. (Z-FG06044/1)
Steel brake plates - 2pcs. (Z-FG08456)
Competition brake lining 2pcs. (Z-FG08456/5)
thanks but still confused. should it have fiber pads or steel pads or pads and steel plates behind the pads
