Chief409
The driveline to the rear diff rubs on the bottom of the engine crankcase when you run hard. Too much flex at the rear of the chassis. I'm thinking about a couple of L stiffeners underneath welded in, running to about half way under the gas tank. Or a steel roll cage.
Or,
Possibly, making windows and attaching those to the roll cage might work. I'll try that first. When I installed windows on the 5b I noticed the roll cage is stiffer. And the roll cage is supposed to prevent rear chassis flex on the Dune Runner, and possibly the MT/TT. Need windows to keep the dirt and sand out anyway on a Dune Runner.
And a aluminum rod brace between the light bucket holes for good measure. The front roll cage arms bow in and out.
Thinking out loud right now.
Or,
