rear cvds?
strodedawg
there was a thread on someone using front cvds on the rear, but i can't seem to find it. can anyone tell what size the spacer was thet they used?
thanks
That was me. The issues I had with the cvd on the rears are the grub screws that secure the pivot pins don't like to stay put, even with red loctite. I used a 3/8 id washer drilled out and chamfered to accept the axle stub. Put the spacer on the inside of the wheel carrier then the inner bearing to sandwich the spacer. I have not had any failures of the cvd other than losing the grub screws unless you use a ton of red loctite. Still have them on and running smooth with the 7075rc carriers.
