Blazemore
Started building a new 5B over the weekend and ran into problems with the mesh of the rear ring and pinion. The meshing is not smooth but feeling like the gears are jumping; best that I can describe it. If I take the front of the trans case and install the pinion and drop the completed diff housing in and hand turn the pinion, its smooth. Once I install the rear housing the gears start to jump. After messing around with this for hours.....I noticed if I unscrew the rear top and bottom screws slightly the mesh gets better but not great. I also removed the pinion shim and it seemed to help some. I'm only hand tightening the screws.
Also for the front I had to make a shim between the pinion shaft and the coupler. Seems someone else was experiencing the same issue:
https://www.rctech.net/forum/oval-l...osi-5ive-b-rear-differential-build-issue.html
After the shim, play is removed and the pinion doesn't slide backwards and causing the binding; smooth.
- The trans case doesn't appear to be damaged
- Pinion gear is flat and not binding, no damage
- Ring gear shows no damage
- Completed diff is very smooth hand turning the cups
- Bearings are smooth, no binding
