Rear End Grease
Adamsky
Elizabethtown, KY
What type of grease / weight do I need to put back in my rear diff on my XT? Their are so many types and weights? 5K, 7K...50,000K??? Also what type of glue should I used to mount the rims to the tires?
The weight depends on how you want it to behave. you just have to experiment with it. Someone else will explain more I'm kinda having a brain fart on it right now. I know a thinner fluid will help turn better so the thicker will have the opposite reaction:screwy:
i can't say what to put in the planetary case bc i used lucas hd oil stabilizer. it's sticky yet thin so def keeps gears lube'd. just make sure to put some grease in the diff case. anything will be fine there as there is nothing from the factory or maybe a touch of some china stuff. mine was dry. i also put grease in my tranny gears.
Mine was almost full of that china crap"grease" I ended up putting 100wt shock oil in the front and 30k diff oil in the rear, it turns nice and sharp and the front us butter smooth and the rear is a little stiffer to turn but that works for my driving style. I trend to like drifting so it would for new but it may not work for you
