bhilly82
I broke the head off the bolt that holds the cross pin in the rear wheel hub. Anyone have a idea of how to extract the bolt. I have never seen bolt extractors that small and there is no way to get vice grips inside that small hole in the wheel adapter. I tried to take a punch and push the cross pin out with no luck.
So has anone had this happen and how did you fix the problem. I didn't even tighten it down that hard.
This happened earlier in the summer and i just ran it this way all summer, but now its time to re oil the bearings or replace that one.
