sperera
Has anyone come accross their receiver battery using more mah once it gets older?
Ive noticed for a while now my receiver battery seems to drain the mah quite quickly over the last couple of months compared to when new.
The battery is the PSR 4600mah that actually takes 5400 mah. If I run 1 tank it will take 1200+mah to peak off and say full where as when new it hardly used anything! The batter has done 60.5 tanks so allot of usage!
I think it might be my switch, before I just used to run plugs but since using a switch it seems to loose mah just sitting there.
Is this normal?
Is this normal?
