cordy
Took my platform out,checked everything,steering servo(805) worked perfect,throttle servo worked perfect.Got to the track started the platform let it idle checked the steering servo worked perfect throttle servo also perfect. Set it down no steering servo movement. On the bench no servo movement,pluged a new servo in ,no movement. Pluged both servos into the throttle spot and both worked fine. I bound two other spektrum recievers ,they both did the same no servo movement. My spektrum reciever in my fg works fine.So I put in my cheap flysky gt3 reciever and all the servos worked fine.So my question is do recievers go kaput?
