Redcat 2.4GHz Receiver have a failsafe?
evilevox
Junior Member
moore, ok
Does the stock reciever have a built in fail safe? The reason I ask is I have moved my linkages over to one side to clear the 5b air cleaner and no matter what I do with the supplied fail safe the thing automagically goes full throttle when i shut off the radio. Its not only annoying but dangerous and stupid.
honestly the stock failsafe that comes with the cats suck.....ur better off pickin up a killer bee v2 if u have the stock radio.....best 60 bux u can spend honestly.....make sure u pick up a y splitter as well if u decide to get it
rebind
have you tried to rebind the reciever with the servo in full brake position since you reversed the servo, it will need to reset the memory for the new position
Im having this issue I put a DX2 in my XT Now if radio shuts off it goes wide open !! How do I Rebind??? Please help Thanks
Are you using the stock failsafe with the DX2 failsafe applied? That could be your issue.
Dx2
I run a DX2 and it works just fine you don't need the extra failsafe, set your servo direction for the way you want it then unhook the reciever from all leads put in your bind plug and and then hook up your power to any port except for on the 3300T don't put it in the telemetry ports, power on your DX and go to bind in the menu, power on the reciever and it should start flashing push the throttle trigger to full brake (don't let off) and then push bind, the reciever should go to solid green and your done put everything back and test. Hope that helps.
