Redcat Racing Rampage XB Questions
dsm600rr said:
If its flooded what shall i do?
Remove spark plug, turn the car upside down and pull the pullstart 10 times or so, that will throw out the gas in the cylinder.
Im not really 100% sure. Put in the new plug and gaped the coil and it fired on the 2nd pull.
So i changed out my dead throttle servo with a Hitec HS-645MG and installed the splitter to use with my RAMTech Kill Switch and Hobbico VoltWatch2.
One issue i noticed is i had to reverse the throttle. In turn, when i cut the power to the TX it now goes full throttle instead the the default fail-safe full brake. Can this be fixed?
So i went out for a run today. Throttle servo and remote kill switch worked great.
Ran into two snags. First, the rubber mount that secures the exhaust to the rear shock tower melted. How can i fix this? Is there a better solution than the stock mount?
Also the brakes stopped working. Any ideas?
Update: I just went back out and inspected the buggy. I noticed a lot of black cotton looking stuff all around the brake area. Looks like they ate themselves up. Not sure why as i didn't even get through one tank and it was on grass.
