DreamState
Do to unfortunate family circumstances I need to sell my MT that I have been building. Comes with a lot of extras including spare custom ported TS reed head and much more. I'm including pictures and a running video.
Price depends on which tx/rx combo you want with it, I have a few to choose from. I will not part it out so please don't ask. Prices are OBO with free shipping, but please no low balling. I also might consider taking it in 2 payments. Also posted on HPIBajaForum, I have 100% good feedback there. http://www.hpibajaforum.com/forum/showthread.php?t=132734
$900 with Radiopost TS401, LiFe pack, and 5 channel rx Almost new, like new condition
$800 with Airtronics M11 and 4 channel rx Well used (was someones track radio) but works perfect. Has brand new screen and wheel.
$700 with stock redcat radio and 3 channel rx Brand new never used ****SOLD****
Truck:
Started as a Redcat Rampage V3 I bought new. The newer V3.
Upgrades
1: All Redcat aluminum upgrades except steering mount B (always out of stock), and body posts (Aluminum body posts are not a good idea)
Motor
2: TS 2-bolt reed case with custom ported (by TurboGlenn) 30.5cc stuffed stroker, lightened and windowed piston. Windows are medium to large size.
3: Very lightweight flywheel (made by TurboGlenn)
4: Fast Eddy bearings
5: 990 carb (only about 3 tanks on this)
6: CPI Pipe with modified aluminum mount bracket to accommodate dropping the body down low.
7: Billet pull start cover and handle with custom steel mesh on inside
8: Unifilter with baja foam insert and outerwears cover
Less than 2 gallons on all motor components.
Drivetrain
9: Converted to 2 wheel drive (front drive shaft, axles, and differential will come with it though)
10: Fast Eddy 10k diff fluid in rear
11: Tempered rear drive cups
Chassis
12: Custom steel mesh in openings down the sides to help keep debris out.
13: Almost all screws upgraded to stainless(the rest of the stainless kit comes with truck also)
Electronics
14: Killer Bee kill switch
15: DDM 5000mah battery (also comes with stock 2500mah battery and charger new in package)
16: Hitec HS-5755MG single steering servo (used for maybe 2 tanks so far, single servo seems to turn harder to the right than the left when sitting still, works great though)
17: Savoc SC1251MG throttle servo (maybe 2 tanks, works great, fast servo)
**EXTRAS**
1: TS reed ported Zenoah 2070 (34mm) wth 13:1 dome, cylinder has been further ported by TurboGlenn
2: 3 extra 34mm lightened windowed pistons for the 2070. Small, med, and large windows.
3: 1 36mm lightened windowed piston, small windows
4: 1 stock crank, 1 stuffed crank
5: Flywheel puller and piston stop tool
6: Stock blue body that I was using for a template to see how much needed to be cut to be able to drop the body so low. It's cut up and a little melted in the back area. Also had a tool box fall on the front of it so the front is squished.
7: unmolested clear body, still has over spray film on it. ( note, the front body posts don't line up perfectly with the pre cut holes, been told this is common on these things. Both the blue one and the clear one have that issue.)
8: All plastic parts that were replaced with aluminum, all brand new never ran.
9: All stickers and manuals
10: Stock battery and charger still in plastic
11: A lot of fuel tubing
12: wheel tool
13: Front diff, bearings, drive cups, axles and drive shaft
14: Stainless steel tube/wire sleeve
15: Stainless screw kit (most of the truck has stainless already)
16: various servo horns and stuff that came with the new servos
17: 2 quarts of caster 927
18: Large spray can of PJ1 foam filter oil
***2 videos*** Feel free to look around my photobucket albums, there are some pictures from the build in there.
1: Cold start video
[/URL][/IMG]
2: Quick run video. This thing could really use some much taller gears. Spins the tires at will all the time. Dead stop on pavement will kick the back end out to the side and light em up
[/URL][/IMG]
***Pictures*** Pictures taken right after above video so it's got dirt all over it. Again feel free to look around in that photobucket album, more pictures in there.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Truck:
Upgrades
Motor
Drivetrain
Chassis
Electronics
**EXTRAS**
12: wheel tool
1: Cold start video
