Redcat rampage mt problems starting
ChAoTiCzz
got the jetpro pipe on got it started once died pretty much right away and now I can't even get it started now
got the jetpro pipe with silencer on it but when I go to start the it won't start but I got it to start one time then just died
A tuned pipe calls for retuning your carb most of the time. With a tuned pipe stock carb setting rarely work. You will need to turn the LSN (low speed needle) clockwise to lean out the low end a little bit.
At this stage since you tried very hard to start it, the engine must be flooded so un-flood it first.
