Redcat Rampage MT
elmerdj
Las Vegas, NV
elmerdj said:
I was wondering what are the main differences between the V1 and V2 trucks.. considering that both of them comes with free pipe and upgrade kits.
Version 1 - http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.6127/.f
Version 2 - http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.6163/.f
The version 1 is more by $30 but that comes with a 23cc motor and servos. Is the version 2 worth buying compared to version 1 considering the price differences and package inclusions?
Thanks,
elmer
Basically with Version 1, you'll have to (you don't have to, but it's highly suggested) tear down the vehicle and put the upgrade parts on it, diffs, arms, etc. You'll get a chance to make certain everything is tight and assembled well. And you get an engine and a tuned pipe.
Version 2, just a roller, but it has the upgrade kit that Version 1 already installed. No engine. You'll also need to go through and tighten all the screws and check things out. You'll also spend at least 125 bucks minimum on an engine, BUT you can choose the engine YOU want. (everything you see in the picture of the upgrade kits are installed on V2)
Tough decision! You can't go wrong either way though! :D
Don't forget to use the code LSF to get an additional 5% off at checkout!!!
