CallsignVega
- Fort Riley Kansas
I have been running the buggy around the track here now for about two tanks of gas total now. There are still a few reoccurring issues that I have been having though. Not long after I received the car one of the rear left driveshaft pins came loose so with the differentials acting how they are designed, was limited to front wheel drive. I thought no problem; just a drive shaft pin and Redcat sent me some new drive shafts. So I receive the new drive shafts (2) in a bag and put one in. After a whopping two minutes on the track, BOTH drive pins flew out of the new driveshaft! Same driveshaft, rear left. I thought, what are the chances that both pins would fly out on the same driveshaft at once?
There must be some issue with these drive shafts that they aren't pressed in with a lot of pressure and they are just centrifugally being thrown out. I took that new drive shaft out that had two minutes of run time on it and put the second new one in, (my last one) and the pins are still in after about ten minutes of run time. I only have about ten minutes on this last drive shaft because my receiver battery died and it had gotten dark outside. Anyways, if this last driveshaft flings the pins out I have some high tensile strength aircraft cotter pins I can put through the holes and see if they stay put. I am not sure though there is quite a bit of torque put down to these wheels, especially during throttle on one wheel jump landings.
The other issue is that rocks and pebbles keep getting into my drive gear case! You know the white plastic case that goes over the four main gears? I am not sure how they are getting in there but these pebbles are tearing the gears up. The pebbles get so wedged in there that the car won't actually move under throttle and I have to pry them out with a screwdriver. Very strange. Even with the clear body on somehow these pebbles are getting in there, maybe from the clutch area.
Other then that there are just minor issues. Like the way the plastic body sits on the car when it rolls over. The body takes all of the impact and is cracked in many places. The body is also warped from the heat of the engine and exhaust and sits on the car now pretty crooked. The suspension has been holding up pretty well, nothing broken there as of yet. Although, even with the front suspension set as high as it can go and the rear suspension set as low as it can go, with full throttle the car still nose dives over jumps every time. I just don't get it. I am not sure what I can adjust/do differently for this buggy to land on its four wheels after a jump. Another minor quirk is that the fuel tank spills fuel out the vent hole every time I run it on the track. I am not sure why.
But besides all of that the car sure is fun to run and my friends like the rooster tails of dirt going everywhere. It has much more visual impact then their 1/8th scales...
