I have refilled some 1/10 shocks, with the plastic bladder, but the shocks on the dbxl doesn´t have this bladder. Instead is a single piece, with a down concavity, isntead of an up concavity like the common plastic bladders.
The issue i have is im trying to refill the rear shocks with 7000 diff fluid, but air gets trapped and i cant screw the cap all the way down as they where, there is a gap of 1mm aprox. Also, when i compress the piston, it rebounds.
Im able to eliminate some air, but not all, because of the down concavity of the cap. Is like a dome that traps air. I fill the shock as the manual states, 1mm below top. Also, im fiting first the black cap without the red anodized nut.
