Regulator Heating up
island
Guam USA
Do you guys know if its normal for the Team Losi Lipo Regulator to get to hot were you can't hold it for more then 10seconds? :confused:
I wanna run already.....
If you are using the 2200mah(?) 2s lipo for the 8T and LST it probably is too small of a pack... I had one of those and I don't think it was made to handle the load of 2 fifth scale servos...etc...
Think of it the same as if you tried to run an 1/8 scale 1600mah ni-mh hump pack in the Rampage...I believe those cells would heat right up as well...
I just don't get why they would sell them in a pack the Losi Regulator and the Venom LiPo 2S 2P 7.4V 2100mAh Hump Receiver Battery Pac?
What do you recommend i use??? So i can run already...
Thanks krashkrieg really appreciate it:)
