Replacement screw/nut set
Sandman_73
Junior Member
Lost another screw over the weekend on one of the front tie rods which put a quick end to the fun. Given this thing is going to loose screws does anyone make a good replacement screw/nut set that contains most of the common sizes used in the MT.
Your local hardware store, they are all metric fasteners.
Take a look at your manual, right down the various sizes and then go to Homedepot and stock up on a bunch of each size. They will likely be much cheaper then buying a hobby specific "kit".
Slimneill said:
Your local hardware store, they are all metric fasteners.Take a look at your manual, right down the various sizes and then go to Homedepot and stock up on a bunch of each size. They will likely be much cheaper then buying a hobby specific "kit".
Good idea! I'll need to locate that parts diagram and build my own set.
