rhino problem
rob142sti
the servo turns one way more then the other.. it will turn the wheels to the right more than to the left.. how do i fix this??
i tried changing the arm to different positions but this just makes the wheels not straight when the servo is in neutral position
If your radio has EPA and subtrims I would check there first. If your trim and/or subtrim is set too much to the right or left you will not get as much steering on that one side. Also, check that you don't have your EPA set low on the side that is causing the problem.
