Rit dye
oldman1964
Well......I had some parts to dye for my 5B so I put in mt gear cover off my MT , guess what.....it didnt take!!! i think because the gear cover looks to be made of H.D.P.E. and not of a nylon make up my other parts. oh well i reckon i'll just paint the inside and outside of it.
Most just run without it. Some tracks require the cover. I never used the cover when I still had gears.
yeah i seen the belt drives, but the tax refund money is just about dried up but it is next on my list! you don't have a problem with the gears rubbing the body or just trim around it. and while im asking all these questions, what about debris getting into the gears?
The gears don't touch the body. They are pretty tough. The debris doesn't seem to effect them. Well, unless you were running the older plastic gears......
Re: Rit dye
Yes, rit changed their formula a few years back and now they won't dye HDPE plastics only nylon based
+1 yea run without the gear cover it keeps the heat in from the gears I run on dirt tracks with no gear cover you will not have a problem.
thanks guys, i was just worried grit and gravel getting in between the gears but it does look like good hardened steal. im gonna have to adjust my body down one more notch cause it seems to be bowed inward a little and will rub on the top gear.
