Rod roll cage vs tubing roll cage
JSoto777
Lovington NM
I want to build a metal roll cage for my chimera. I'm thinking of doing 3/8 aluminum. I just don't know if I should go with rod or tubing.
I want thins to be very strong
Any suggestions??
my 2 cents
With aluminum you should go with rod. It is stronger but the main reason is the welder will have a hard time welding the thin wall without melting threw.
Consider 4130 steel tubing, MUCH stronger and your welder will have no problems welding it, in fact, I'm sure he would prefer steel over aluminum.
Ol said:
With aluminum you should go with rod. It is stronger but the main reason is the welder will have a hard time welding the thin wall without melting threw. Consider 4130 steel tubing, MUCH stronger and your welder will have no problems welding it, in fact, I'm sure he would prefer steel over aluminum.
How heavy is the steel compared to the alluminum?
Where can I get this steel tubing?
It's not cheap so you'll want to do some tests before you start bending and welding. Try making the cage out of wood first. You can get 3/8th rods cheap.
Use a hot glue gun to join the dowels. Once you have it looking like you want it to measure all the length's to determine how much tubing you'll need.
Ol said:
It's not cheap so you'll want to do some tests before you start bending and welding. Try making the cage out of wood first. You can get 3/8th rods cheap. Use a hot glue gun to join the dowels. Once you have it looking like you want it to measure all the length's to determine how much tubing you'll need.
Good idea i might have to build one....
My dad got the hook up at work got some pipe to practice on. I have a little experience bending pipe so I think I can do this fairly easy. Also I have the plastic roll cage that's in my chimera that I will use to copy.
I'm gonna bend and cut all the pipe and the welder will weld it for me. :)
I think I'm gonna go ahead and try out the 4130.
Which thickness is recommended?
.028
.035
.049
.058
.065
.083
.095
We'll I started last night after work. And finished all the bends and most of the cuts. Just got to get about a foot more of 3/8" then 18 inches of a smaller pipe. Here are some picsView attachment 6954
/monthly_2014_01/image.jpg.97f1f512000631685d8198df3ff9c4e6.jpg
You should add a bar to fasten it mid chassis as well. That will help with chassis flex. They should of done that on the chimera cage and eliminate the motor cage.
It's look'n awesome!
RCDAD said:
You should add a bar to fasten it mid chassis as well. That will help with chassis flex. They should of done that on the chimera cage and eliminate the motor cage. It's look'n awesome!
Thanks, and I will consider the mid chassis bar. Cool
