- Reaction score
- 22,962
I can't see how the second ring is going to generate enough friction to cause the engine to overheat without tell tail wear signs on the cylinder. That would be a lot of extra tension, and it would go away as the engine wears in. Possibly it lowers dynamic compression enough to avoid some heat build up, or another factor, but it's not the second ring causing too much friction. If anything it would help to transfer more heat to the cylinder.Friction is why. The first year of the rovan 45 were actually decent. They were single ring. The dual ring 45 sucks and gets hot.
You can actually make these cheap engines run well. You just have to dissemble them to check for shavings -bearing or gasket errors.
