I was thinking the same. Plus it don't have the snap I'd expect it to have if he had a 9500 or 10k spring.Nice looking truck.
I have a question, why does it sound like your clutch has a crazy high rpm bite? Or sound like your clutch is slipping??
I run 6500 rpm clutch's and sometimes they can sound different to mates 8500 clutch's, but the one above just doesn't sound right.I was thinking the same. Plus it don't have the snap I'd expect it to have if he had a 9500 or 10k spring.
baja max t comes geared stupid low at 17/57Its probably just geared low
Nothings binding I’ve had 3 different clutches in the truck they all sound the same the truck is 40 lbs. that doesn’t help and the stock 17/57 gearsI run 6500 rpm clutch's and sometimes they can sound different to mates 8500 clutch's, but the one above just doesn't sound right.
@Go fast check your clutch is good and make sure nothing is binding.
Maybe a quick douche with carb or brake cleaner just to ensure no grease or gunk is causing the shoes to slip.Nothings binding I’ve had 3 different clutches in the truck they all sound the same the truck is 40 lbs. that doesn’t help and the stock 17/57 gears
Just checking fella as it didn't sound right is all.Nothings binding I’ve had 3 different clutches in the truck they all sound the same the truck is 40 lbs. that doesn’t help and the stock 17/57 gears
