Rovan Baja servos with LiPos
As Striikar said, you're better off buying a BEC.
Personally I would suggest a 10A Castle BEC, they're adjustable and they actually tell you the amp rating they were designed for.
Since it allows you to adjust the output voltage, in future if you buy a higher voltage receiver/servo you can run them at 7.4-8.4V.
https://www.modelsport.co.uk/index....KCuwA31wJlSvLCudrP9yfpPptctTxsDUaAke3EALw_wcB
If you buy one, you can register with Castle to get a free program module which you use to plug the BEC into your PC and select whatever voltage you need.
