Rubber exhaust stinger?
amstel78
Does someone out there sell a rubber exhaust stinger that I could attached to the Redcat tuned pipe? I'd like to draw the exhaust further away from the wing assembly.
You can use hi temperature hose. I use radiator hose to cuple the header pipe to the rear dom and it works good .Go to your local auto parts store. Im sure they will have what you need
Great suggestion. I was thinking of something along those lines if a more refined product didn't already exist.
Sent from my SGH-T989 using Tapatalk 2
Check the large scale rc airplane sites. There is a white high temp almost plastic feeling hose. You literaly heat with a torch to make it expand then put it on and it shrinks back no clamps needed. Our exhaust don't quite get hot enough to expand it again. I build and repair some big scale rc competition planes for a guy that uses it is cool . Think one site is tony's large scale toys.
Thanks for the tip, I coulda used that stuff when I broke the 'tension spring' mount point off the header for my CPI pipe...hose clamps kept chewing through the regular blue hose...think I'll pick some up just in case..
Great to have you back Sprint!
