Vtx_f
I took my MT out for the first time in a while. Everything was going fine until i went over a small hill. The truck kind of sat for a second while I was still on the throttle. I thought it was just spinnig the wheels... After the hesitation the truck began to return to me. I ran the truck back home on its own power. Everything seamed fine. Now I'm finding the wheels are not turning freely. It seems like there is binding somewhere. When I turn both the front or rear wheels in the same direction something is definetly preventing them from turning. After a visual inspection I can't visibly see anything wrong. I removed the stacked 25 tooth gears to ensure it was not the clutch bell (it's not). I also removed the filter and carb to check the gearing in the center of the truck, nothing seems to be wrong. Do you guys have a trick for checking the front a rear diff's so I can isolate the problem? Or for that matter, any ideas to what might be the problem? As always thanks for all your help....!
