choke "stops air" and the piston movement pulls gas into crank case .... now the gas vapor pushed to the top of the cylinder...the vapor/air mixture ignite for combustion reaction which drives cycle again. the negative pressure side(carb) of the mill sucks air and fuel to combust in chamber for stroke power and moves to positive pressure side (exhaust)
with the volatile nature of gas, it will be gone after shut down in a short amount of time. this is temperature dependent, the ambient temp as well as motor temp. a hot motor with a wet case will pop with one pull but can be easily flood with TOO many snap pulls. a cold motor ---> choke OR 4-5 full slow pulls
a "choke kill" literally drowns the ignition...to wet to burn, only vapor will burn.
after a 30 min run i shut down, about 10 min cool period , then 4-5 full slow pulls and pops in about 2 snap pulls.. but if its cold below 50F finger choke, one snap pull
practice! this practice contains feel, sound and smell ...that will tell what to do
no theory at this point, its just experiential -->practice
