Runs with choke closed but not open.
Hi all, I am having issues with my truck (32cc) not running when I open the choke.
It runs and starts with the choke on but as soon as I open it, it dies. Also when I apply gas with choke on it dies.
I have a Walbro 1107 carb (factory settings) and an aluminum intake from Ddm. I also have the redact blue aluminum air filter and tuned pipe.
Any advice would be appreciated!!
Is your gas tank cap vented?
Open the gas tank and try. If it runs fine, you got your culprit and you can do a search on the forum or google "gas tank venting".
Believe I found the culprit. Intake gasket appears toasted. I did however order the fuel tank vent kit as well as a turtle racing pull start w/ outerwear.
Will update after I get the gasket and vent kit.
