S254 Engine for the boats
  • Thread starter Thread starter magnum57
  • Start date Start date
M
magnum57
Guest
Hey guy’s has anyone run the RCMK in there RC boats. I’m thinking about the Sikk motor from DDM and heard about this one comes stock @ 5.2hp and has the same mounts as the Zenoah G260. $260.00 turn key seems like a great deal. You put a 5.2 hp with a wet tuned pipe and were in the 6+ hp zone. That’s when boating gets interesting….. :eek:
That'll work......boating's always interesting......right around 40mph is when it gets hairy....depending on the wind and waves.....flipped mine coming out of the hole hot, too much prop wash on the rudder, got sideways, cavitated and flipped....brought her in as quick as I could with her bow 3ft out of the water...must've had 2-3 gallons in her.....oh how I miss her :(
getten sideways @ 40mph is hairy for sure. i run the futaba fasst system and had the steering set at 100 and hit a turn at around 40 also and flipped one of my boats:confused: full of H2o got it started pretty quick and saved it:D Scary for a few moments. i want to beef up this 52" WHH man of war hull so that why i'm asking about motors that maybe you guys have used.
/monthly_2009_03/583c605705ff4_WHH1.jpg.b70ce761932c3828332c7c0629702029.jpg
/monthly_2009_03/583c605707538_WHHstockmotor.jpg.d327f1112f8ece53de2b16fda3cdcf43.jpg
I found the specs for this motor. For some reason its been a seceret for a while but now cats out of the bag:D
This should make this hull fly:eek:S254 Gasoline Marine Engine (4 bearings crank case)
Specpication :
Power: 5.2HP @16,000 RPM
Timing: 30 degrees BTDC @ 7,000 RPM
Compression Ratio: 10:1
Carburetor : Walbro WT-929 carburetor(15.88mm bore)
- 4 bearings Dicasting Crankcase
- Adjustable Ignition Coil Mount(High and Standard)
- Air flow groove in Crankcase for High Speed
- Modified piston
- With pull Starter
- Walbro WT929 caburater
- R254 Cylinder
