charlieboy
its easy just pull the black plastic knob off (quite hard)then under that you will see a brass coloured nut undo that then you can remove the knob from the handset just cut the 3 wires resolder on to the switch one on each pole brown on the center pole mine still wont go off when handset switched off for some reson but i not a worried about that it was more twisting the knob was the problem also theres fair bit of room inside the handset for a small switch good luck let me know how it goes cheers for your help mate
will do mate, no worries see what we can do when we put our heads together
