Screen Modification Pull Start
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
Pull Start Screen Modification
I thought it a good idea to put a thread together for this basic modification.
The pull start vent holes allow a ton of crap to get sucked into the rotor area.
It is recommended everyone get a pull start outerwears.com but for those who cannot afford it right away here are a couple ideas of what to do.
You can remove your pull start and either install a screen modification on the outside or the inside. Here are a couple of photos of both.
Inside:
https://www.largescaleforums.com/forum/attachment.php?attachmentid=1470&d=1220023311
Outside:
Install the same type of window screen cut to fit over the vent holes. I used 3M self adhesive by spraying it on the screen and setting it in place. Other adhesives could also be used.
See Engine Screen Modification.
https://www.largescaleforums.com/forum/showthread.php?t=4027
That's a good idea, I never thought of that. My pullstart started acting up about 6 tanks worth of fuel. So I bought an Outerwears cover for it, but this tip is cheaper!
Good Tip..
Trip..
starter cover screen mod
Hey Trip: here is a picture of my starter cover screen mod..You can see the outerwares cover also...I used automotive screen for body repair and silacone...
AKASlawhammer
I've done a couple now, using something similar to slaw ...an aluminium mesh for reinforcing fibreglassing and used epoxy to stick it on...a good mod thanks BTB !:w00t:
