Sharkey
i read the tutorial on sealing up the diff, its exactly how i was thinking, except for one thing. im not thinking of running grease in my diff, id like to run silicone oil (thinking 50k wt). sealing the sleeve to the carrier and around the ring gear will do the trick in those locations, my only concern is the outdrives. now grease wont leak between the outdrive and carrier, but oil will likely seep. has anyone tried sealing them up with an o-ring??? anyone had any luck with silicone oil in an fg/duratrax type diff??? if so, how did you seal it up???
