seen this on ebay MAGIC MESH Fine Weave
coopycoopy
LEIGH / MANCHESTER / UK
just ordered some magic mesh off ebay looks like it could be applied to the baja to stop crap and grass and leaves getting in to places u don't want em ! don't know how strong it is but its available in all colours and is self adesive ....:donatello:
Packaged in 2 ½ x 36-inch rolls, Magic Mesh is pressure sensitive—sticking where it’s placed—yet repositionable—so if you change your mind you can peel it up and do it again. New this year, Magic Mesh is also available in 12x12 sheets. Magic Mesh is flexible and trimmable. Use it with Sizzix die cuts, Fiskars punches, or any cutting system. It works with Accucut, Boss-Kut, Quick Kutz and other laser die cut systems as well.
'sticking where it’s placed—yet repositionable—so if you change your mind you can peel it up and do it again.' how would it hold up against heat as you know something which is sticky when heated up becomes softer and easy to peel off.
