shade82000
- St. Albans, Herts
Hi everyone, I was looking for a dedicated forum for largescale cars and I came upon this one!
OK I was out running my Baja SS today and I seized my engine. First the spur gear got shreaded and I opened up the throttle to adjust the needles a bit for the next run and the engine just died.
I've just read in a manual for another engine that these petrol engines should not be allowed to WOT when there is no load. I won't be doing that again.
I managed to take the head off and there was a 1/2in x 1in score mark on the cylinder and piston, also the piston ring was damaged.
The spark plug was a matt grey colour.
I got a 29cc head a couple of months ago and it came with a 2mm stroker crank.
If I put the original head & piston back on then will I be able to keep the same crank/conrod or should I completely take the engine apart and put the original crank back in?
If I keep the current one in then will I gain or lose power, or will it just not work at all?
Also, would the engine have got too hot because it was running too rich or too lean at high RPM? I always get it the wrong way round with petrol engines.
Cheers!
Cheers!
