ChuenouXiao
I don't like the stock throttle horn for it's plastic. Any recommended aluminum horn that will work with my XB with very or no mod? Please let me know.
No....I have a high tech servo for throttle. I think my plastic piece is wearing out. The part that connects to the servo gear .....RCDAD said:
Yea... I think I have a few aluminum lying around but I think they are not the exact size. May have to cut, slice and measure them before using them. BTW... RCdad... I'm going to copy your emotion cartoon ok?RCDAD said:
I have confirm that its not that the plastic horn is wearing out at servo gear but.... its my set screw for my break are coming loose, tightening my brakes. Resulting in my car breaking and locking my brake shaft. With that, my throttle servo is somehow locked at a 13% acceleration no matter how I set the trim. I fixed it by taking my gear plate and everything apart, loctiting the brake set screw on the aluminum brake piece and everything seems fine now. Got my hands crossed....ChuenouXiao said:No....I have a high tech servo for throttle. I think my plastic piece is wearing out. The part that connects to the servo gear .....
Sounds like you got it all under control. Give your self a pat on the back.ChuenouXiao said:I have confirm that its not that the plastic horn is wearing out at servo gear but.... its my set screw for my break are coming loose, tightening my brakes. Resulting in my car breaking and locking my brake shaft. With that, my throttle servo is somehow locked at a 13% acceleration no matter how I set the trim. I fixed it by taking my gear plate and everything apart, loctiting the brake set screw on the aluminum brake piece and everything seems fine now. Got my hands crossed....
Yeah, Hitec horns are usually pretty durable. Glad you figured it out.ChuenouXiao said:I have confirm that its not that the plastic horn is wearing out at servo gear but.... its my set screw for my break are coming loose, tightening my brakes. Resulting in my car breaking and locking my brake shaft. With that, my throttle servo is somehow locked at a 13% acceleration no matter how I set the trim. I fixed it by taking my gear plate and everything apart, loctiting the brake set screw on the aluminum brake piece and everything seems fine now. Got my hands crossed....
Holy moly! Adjustable huh?Deluge said:Also, for reference. Here are a few aluminum horns that will work with the Hitec throttle servos...OFNA CNC Machined Aluminum Double Arm Servo Horn (24T-Hitec)
Hudy 1/8 Off-Road Aluminum Double Arm Servo Horn (Black) (24T-Hitec
Racers Edge Aluminum Pro Adjustable Double Arm Hitec Servo Horn (Black)
Indeed. Good stuff.ChuenouXiao said:
Couldn't tell ya, dude. Isn't that a Turnigy servo?tsudo5th said:Does anyone knowwhat aluminum horn will fit on this servo?![]()
