servo question
RampageCrazy26cc
,VA
last year my rampage radio system burnt,the rx,both steering servos and the battery,burnt,so i bought a new steering servo and put a traxxas rx in and been happy ever snice,i have the one steering servo under the battery box.
the problem,is when i turn left the servo arm is hitting the battery box,is this normal or not?
Not normal. If you are just running one it would be easier to have it on the right side.
i tryed to put it on the other side the other day,but it wouldnt line up with the steering assby.
are the servo horns left and right?
RampageCrazy26cc said:
i tryed to put it on the other side the other day,but it wouldnt line up with the steering assby.are the servo horns left and right?
No. You can install the horn after the servo is mounted.
- Mount the servo.
- Power on so it centers.
- Install arm pointing straight up. The linkage can bolt to the bracket off the arm if needed.
- Some servos require you run them on the reverse setting on your radio.
RCDAD said:
No. You can install the horn after the servo is mounted. - Mount the servo.
did all that but the arm coming off the servo didnt want to bolt to the steering assby
the reason i say this is i just installed the same one my mt today, i put it in withe horn towards the front of truck and the linkage didnt line up. (this is for the servo on the right side)
Horn should be on the back side of the servo.
yup, old age kicked in and had a brain fart and forgot which way it went, had to take apart and start again LOL!
Re: servo question
If the horns on the back side it should line up unless the steering link is shortened... Might have to turn it to make longer or shorter
