mik3y
So I finally set up my dual steering Rhino Digi 4 servos today using the JR Matchbox to match up the servos so they don't fight each other.
I hooked up a servo volt/amp meter and here is my question:
When my steering is in neutral, i am getting a reading of 0.03 amps (both servos are quiet)...no buzzing noise
When I turn the steering ALL the way to the Right and maintain holding the wheels to the right, the amp meter reads about 0.40 - 0.45 amps and the servos..the servos make a little buzzing noise. Is that Normal? Should there be any current draw if all im doing is holding the steering to one direction? Also, is the buzzing noises normal too?
Same thing goes when I turn the wheels to the LEFT...I amp meter reads about 0.40- 0.45 amps.
Any insight will be appriciated.
thanks
thanks
