Servo
bobvic1217
replaced hexfly HX-9CS with another one... and the same thing... intermitently working. Took apart, and found the soder came loose. Put back together and nothing.... what is a good replacement for the XT Steering?
replacement
What is a good replacement for the hexfly? 1st one last 30 days, and the second lasted 30 minutes... what can i replace it with without modification?
the1320god said:
i would think if it has duel servo steering then u would need to replace both... the 5755 is prob faster then the stock ones.
i thought I read somewere that people were using just 1 but not sure witch one there using I have one 5755 will get one more if needed
You can use one. It is just an option. That 5755 is strong enough. You can also use two on the MT and keep the factory setup.
Never replaced servos let alone two of them at $70 a piece. Just didn't want to burn them up unless you guys think it will be ok and help me out adjusting these monsters.
Thanks for the response. Broke in the MT the other day. Unfortunately I hit a fire hydrant and bent up the right front end. Oops. :( Anyway I got the carb installed, the pipe on and now waiting on parts to rebuild the front end.
Thanks again.
