alfred e numan
- Reaction score
- 0
Usually when the stock servos go nuts on the cats, these photos show why., This time the hot-+ wire broke at the solder joint. Its an easy fix, Just stay away from the lead free solder- use either a 12-15 watt iron, or if your quick, Radio shack sells a 25 watt pistol grip iron on the cheap. The o-rings on the case halfs- strech the rings on the outside of the cases, tighten the case screws until there is just enough room for the rings - put the rings in place, then tighten the 4 case screws down. As you can see- the tranny gears are all metal. very durable- The hi-tec stuff- all metal also, with the exception of 1st gear- its nylon- Mine have not failed yet--yet.
