Setups
Chief409
Rosamond, CA
I have my Dune Runner now, :D and I'm looking for some setup info. Caster, Camber, Toe in, Ride Height, shocks in general (like oil), etc. Mainly I'm planning to run behind the house bashing, but the track at Glen Helen is a short drive away, and I might run there on occasion. Any info is appreciated.
Before I setup my R/C's, I run them. Then I decide from there what needs to be adjusted. Then I do one adjustment at a time, so I can track the progress. It really depends on your driving style and where you're running.
I need a baseline setup, no two settings are the same on the front. The rear appears OK. If you look at the head on picture I posted in the "Almost Here" thread you'll get an idea of what I'm looking at.
The picture doesn't show it well, but I need to set the steering linkages also. If I set one to straight, measure with the calipers and set the other side to that, and perhaps set the camber to -1 degree or so, would that be close. The rear looks OK. I can see a work stand for this in the near future, like when they're in stock. lol
