paedbo
New Member
For those of you that haven't broke your motor mounts ( yet). When you do if you buy firehammer mt motor mounts be prepared to do some extra work. They do not use the same screws on one side underneath . So i suggest buying the screw set along with the motor mounts. The aluminum motor mount on the right side also needs a stand off or spacers. ( Not sure if the fhmt already has these) And one of the screws that hold the upper support plate the one over the rear end, uses a machine screw instead of a plastic screw.
