Shock oil question?
LosiDBXL
I'm i right in thinking most of you have added 5k diff oil in your shocks?
I'm just bashing mine and from the factory the back shocks just sag so was thinking some new decent oil in them should do the trick
Thanks
No they need DDM springs and I'd put 7000 in them and same in the front
While you're at it Losi hard foam all the way around helps a lot to let the suspension work
The foam that comes in the 5ive truck it's a lot harder and the tires do not deform as much when you hit a bump
I just race but it helps car take the bumps
It works well in the stock tires that comes on buggy
It's money well spent in my opinion
So I'll look at the ddm springs but any other set ups people running with the stock springs?
