shock oil
ill be using this on my 4WD MT which only has 4 shocks just wanna soften up the front and rear suspension. currently using fg 2000 front and 1000 rear and don't want the hassle of driving up getting the fluid fg dealer while i can grab different brand shock oil at a near by hobby shop. so what weight shock oil do you guys recommend?
Stick with 8 and run 50 rear 60 front or 50 all the way around. It will soften up. Make sure you don't run too big a spacer on the shock too. I think a bottle will do 4 shocks. So try out a few different ones.
followed the suggestion you guys made with 80wt front and 55wt rear signicant change thx guys now onto next project building back my 2WD MT
Now I know what spacers your talking about. The dampeners. Its all up to you. That is the way to adjust tension of the spring Try to swap them around and see how you like it. If you feel sag use the bigger clip. I think I have small in front and big in rear.;)
